ls vtec
Discussion in 'Engine Building' started by monty92, Apr 24, 2009.
  1. monty92
    monty92 New Member
    regina, sask
    buildin an ls vtec what horse power numbers can i expect?
    92 integra b18
  2. newb
    newb phresh VIP
    Backwoods Northwest
    12 kajillion horse.
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Stock bottom end and stock VTEC top end (around 185-190hp to the CRANK not wheels)
  4. Matts96HB
    Matts96HB . Moderator VIP
    My god. You really expect us to be able to predict that without any specifics at all?
    CARFROG, you can't even be assured of that. What about the tune? GSR to B16 to ITR or CTR is going to vary quite a bit too.
    Good god. Fail.
  5. CAFROG
    NOR-CAL
    Thats based on stock head and bottom end with the nastural compression change when applying a VTEC head to a non-VTEC bottom end (yes ITR or CTR will vary slightly. I sad stock....not tuned or chipped or ported or poor man type r. I said STOCK
    And the varences if all applications were STOCK...NO NO NO they WILL NOT VARY that much.
    Obviously the original poster is like MANY post that are terribly Vague and leave mounds of information unsaid. I gave him a ballpark figure that is VERY REALISTIC and gives him vague info based on the vague question.
    Thanks for filling me in on all the different heads...although I was already aware
  6. newb
    newb phresh VIP
    Backwoods Northwest
  7. monty92
    monty92 New Member
    regina, sask
    sorry a stock bottom end with the head off a 95 gsr
  8. BLOWN-EK
    BLOWN-EK New Member
    San Diego
    you should make around 165 whp
  9. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    You'll blow the welds on the intake making that kind of power.
  10. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    New issue of Project Car, 92 EG with a GSR LS/vtec. Obx cams, retainers, springs and aftermarket intake manifold. Dynoed 178hp to the wheels, ran a 9.7 in the 1/8mile.
    My old 91 Civic 4-door. B18a1 LS, 2000 LS B18b cams stock valvetrain, Obd2 B18b intake manifold and 4.44 cable transmission on street tires. never dynoed but ate Gsr swaps and ran a 9.5 in the 1/8 mile.
  11. newb
    newb phresh VIP
    Backwoods Northwest
  12. Matts96HB
    You obviously don't understand what I'm trying to say here.
    You can have two identical LS-VTEC engines and they are not going to run the same, nor put out the same amount of power. There are too many variables even in tiny details of the engine.
    So no, your guess was not very realistic.
  13. monty92
    monty92 New Member
    regina, sask
    would getting an after market computer like hondata be the best way to get more power? quick
  14. monty92
    monty92 New Member
    regina, sask
    sorry i got more specs b18a block with a b18c1 head and p28 ecu, short ram intake and 2.5 inch exhaust? what numbers am i looking for an estimation horsepower torque? thanks
