Ls wiring harness
korey
could I use the Ls wiring harness for the ls swap into the 97 dx coupe? Woudld it work?
:no:
the 3rd gen integras have a 2 piece engine harness (it connects to plugs at the shock towers before going through the firewall to the ECU)
6th gen civics have a 1 piece engine harness (it goes all the way through the firewall to the ECU)
you need to modify your stock harness by lengthening a few wires
its not that hard .... just make sure you solder all the splices and seal it up good
Originally posted by civicious@Feb 14 2004, 12:07 PM
the only harness you can use in a 96-98 civic is a 96-98 civic harness.
period.
2nd that
