Lsd On Gsr Tranny
willevans
hey guys,
im unfamiliar with lsd and how it attachs etc. first off if anyone could explain that it be appreciated.
secondly i was looking at a s13/14/25 viscous lsd and was wondering what exactly i would
need for install, if it would install on a gsr tranny thanks alot
lsd - basically gets the power to both wheels for u and is located in the tranny attached to the ring gear and the axles are attached to it. as for nissan diffs, dont look there, wont fit, they for rwd. u can use an oem ITR/CTR lsd or any jdm, gsr/b16 oem lsd. and of coarse there is aftermarket.
its pretty much a whole new differential. the nissan diffs wont fit because the gear tooths are different(i think), the gear ratios will be different, the diff is for rwd(the pinion gear is positioned different), and the diff wont fit onto the honda axles.
