Lsd Transmission
Discussion in 'Engine Building' started by ericmugen, Jan 7, 2003.
  1. ericmugen
    ericmugen Junior Member
    Puerto Rico
    My friend buy a JDM GS-R motor and transmission but how i know if this transmission have LSD?
  2. LIhybrid
    LIhybrid Junior Member
    You have to drop the tranny and check if theres an LSD in it, or try doing a burnout and if one wheel doesnt spin then you know theres no lsd.
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    If it was an OE LSD then it will be stamped on the tranny. Also you can just lift the front end of that car up and if you spin one wheel and the other spins, then you have a LSD
  4. bucketSol
    bucketSol Member
    if you haven't installed the motor... just look at the holes on the tranny where the axles go into... if its gota LSD then you will NOT be able to see through to the other side... if you see rite through... in and out the other side... no LSD.
  5. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    fuckin redneck, haha jp bro
  6. 5genracer
    5genracer Senior Member
    Frozen north - ND
    actually, if you can see all of the way through, then you have an lsd equipped tranny. If there is a "rod" in the tranny, no lsd.
  7. chet
    chet Senior Member
    st petersburg, florida
  8. ericmugen
    Puerto Rico
    I know that making a burnout I will know if the transmission have LSD but the transmission was not mounted.
  9. SolReaver
    SolReaver Senior Member
    Actually, it has to spin in the same direction, if it spins in the opposite direction, then you dont have LSD
  10. Integra1990
    Integra1990 Senior Member
    omaha nebraska
    on the topic of lsd's, will someone explain to me how they work? and y they r so good?
  11. prawjEKt Cx
    upstate NY
    real limited slips will adjust what tires need how much of the power, like lets say your going straight each wheel will get 50/50, but lets say your going left, the left wheel doesn't need as much power as the right, so your power distribution will change too 40/60 lets just say.... that's the general idea... i'm not gonna get too in depth with it because i'm sure there are people on here that have done alot more reasearch on it and can explain it better.
  12. puzzles
    puzzles Junior Member
    is lsd the best tranny out there and is there any for automatics or is there better one's for b16a automatics. :worthy:
  13. pissedoffsol
    you can start buy getting rid of your moms automatic
  14. E_SolSi
  15. Integra1990
    omaha nebraska
