Lsparts For Sale
Discussion in 'Parts: For Sale/Trade/Wanted' started by toknology, Feb 15, 2003.
  1. toknology
    toknology Junior Member
    lynn,mass
    i have 2 ls motor,trany(cable),ecu,axles,shift linkage.suspen,or post what u want make offer
  2. 90vtec
    90vtec Senior Member
    Fuel Pump?
  3. whatdahieu
    whatdahieu Senior Member
    how many miles do the engines have? have they been modified in any way?
    are there any cracks in the blocks? are these complete engines(head, fuel rail. manifolds, etc.....)?compression and leak tested? If you could answer these questions or have any replies that would be helpful let me know.PLEASE be truthful no b.s. if you don't know that's better than lying.
    Let me know how much you want for one complete swap engine, tranny, ecu, axles, shift linkage
    THANK YOU FOR ANY FEEDBACK!!!!
  4. toknology
    lynn,mass
    1 of the motors is apart.the block is still assem. the head has the vavles,spring attached to it.i do have the cams,intake manifold,distrubitor and ex manifold.i will sell the block 150.00.the head 100.00.transmission for 200.00.this motor has approx.150,000 milescar was rear ended and was still driving.reason for disassemble was thought my friend was buying the block.the other motor has 130,000 miles and it is still in the car running good.that motor will be selling at 800.00 for everything under hood.for the whole car 1900.00 both are b18a
  5. 1_deuceracing
    1_deuceracing Member
    Where are you out of toknology? I'm interested in buying your disassembled block if you could put together some sort of bill of sale and what car it came out of. I'm in southern California. Let me know, thanks...
  6. toknology
    lynn,mass
    im sorry i do have the ecu,axles,shift linkage.ecu 40.00. axles bothsides 50.00. shift linkage 50.00
    shiping not included.
  7. D See 2
    D See 2 Senior Member
    Baltimore, MD
    hey, please, i need the rear tranny mount bracket that goes from the back of the tranny to the rear crossmember. if you have one how about $20 shipped? i need it for the new mounts i have bought. thanks alot and let me know. -Derek
