Manifold swap
Discussion in 'HYBRID -> ED-EF / DA' started by sicivicman90, Oct 26, 2010.
  1. sicivicman90
    sicivicman90 New Member
    I have a 90 civic si with the d16a6 what do i have do i have to do to put a z6 intake manifold on it.
  2. sicivicman90
    Please help
  3. 8secHonda
    8secHonda New Member
    it should be a direct fit w the head u have.. i would think anyway..
  4. EF9_boy
    EF9_boy New Member
    TX
    you sir are correct
  5. sicivicman90
    ok but wut do i have to do about the injectors. its got something like the y7 set up on it with the plastic on top?
  6. 8secHonda
    it should all be a direct bolt on bro..
  7. EF9_boy
    EF9_boy New Member
    TX
    i dont think y7 injectors will work as they are obd2 and your injectors are obd0
  8. 8secHonda
    ahh thats right man the plugs r different aint they ...
  9. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    swap the manifold and put your old injectors in
  10. skellagher
    skellagher Elder Driver
    Newark, De
    i think his problem is his car is dpfi
  11. EF9_boy
    EF9_boy New Member
    TX
    its an si so its MPFI
