Manual trans fluid
Discussion in 'HYBRID -> ED-EF / DA' started by MRG719, Apr 6, 2010.
  1. MRG719
    MRG719 New Member
    Have a 91 hatch with b18a1 mated with a1 trans what fluid does the trans take
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just get eom honda fluid or 2nd best thing castrol motor oil
  3. eg6sir
  4. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    I swear by Honda MTF. I've tried damn near everything too.2nd best to me is the Royal Purple stuff. I forgot the exact name of it though. The Redline stuff isn't too bad either. Next thing i'm trying though is the Amsoil stuff... My experience with synchromesh wasn't great. To me it was on par with regular 10w-30 motor oil :shrug:
  5. phunky.buddha
    Dallas / Fort Worth, TX
    Honda MTF if you want to use the right stuff according to the factory recommendations.
    GM Synchromesh with friction modifier if you want the best feeling grind-free transmission. There are TWO kinds of GM Synchromesh- the one without friction modifier will just feel like you dumped regular 10w30 or MTF into your transmission. I forget the exact part numbers for the two- but the friction modified stuff has a part number that looks like you're just going down the number row on your keyboard.
  6. distant imports
    distant imports New Member
    Honda MTF only or Torco MTF is what we use in our 11,000 rpm race cars and we have not had a problem. I will tell you that you will scatter shift colors and syncros if you use just motor oil.
    Mitch
    Distant Imports
    Owner
  7. DA16killer
    DA16killer New Member
    PA
    Motuel 10-40 should do the trick. thats what i use in my DA w/JDM B16. havent had any problems. i daily drive mine. have about 5000 miles on my most recent change and its smooth as hell.
  8. leemo559
    leemo559 New Member
    use atf...or 10w30
  9. phunky.buddha
    Do NOT use ATF!
  10. Jorsher
    Jorsher New Member
    Honda MTF.
    It has been reformulated and is "friction modified."
