Map sensor question
tuner2484
Can you use a 94-01 integra map sensor on a 91 integra? I have a BDL throttle body that has the opening on the bottom for the 94-01 integra map sensor but I have no idea if theres a way to connect my 91 integra's original map sensor harness to the 94-01 one? The reason I'm asking is I found a 4bar map sensor for my turboed teg that fits the BDL throttle body but the sensor has the 94-01 connector and wanted to see your guys input on connecting it.
seeing that a map sensor is required to deliver the right amount of fuel/air. I would think so. ;)
For the most part they all work the same in conjunction with other sensors.
I think if you change from stock map to 4bar map , it will not work ok if you don't change it on the ECU !
