i'm getting a map cel whenever i got above 5500 rpm's (roughly). i have a turbo ls/vtec and i first thought it was my stock map sensor that was causing this because of the high boost, but now i'm not sure. i turned the boost down to 6psi and it still threw the code. the code goes off when you reset the ecu. what are the possible causes for this?
