MAP Sensor
Discussion in 'Civic and del Sol - EG and EK' started by 1sikef, Dec 1, 2008.
  1. 1sikef
    1sikef New Member
    ok i just started throwing a code for map sensor so i went and got a new one, put it in and no more code, but im burning way more fuel than i usually do, you can smell it, so my ? is will the map sensor cause this and i think i forgot to put the o-ring on because i found it on my garage floor today.... would that o-ring missing cause the map sensor to mess up, and burn too much fuel
  2. D16SiHatch
    D16SiHatch New Member
    well if its leaking enough air i suppose its a possibility. put the seal back in and see what happens
  3. nasty ness
    nasty ness New Member
    sorry for jumpin on your post but i've been registered for a couple of minutes and i tried searching, and still don't know how to start my own post.
    whats up everyone...well I have a problem with my map sensor to...i swapped out the engine and some how threw out the connector to the map sensor...i have a seperate plug and I'm trying to run it directly to the ecu...I know I'm suppose to use d17 d19 d21 but my problem is since the colors are diffierent i dont know which goes where...all i need is to the colors on the actual connector...and maybe a pic.
