92civicb18b1
The Trisexual
Ok so I keep hearin talk about map sensors, unfortunately im using a TB from the d15, it obviously doesn't have the map sensor on top, i was wondering if the map sensor was loacted on the firewall, because once again, I have to replace the TPS and want to use the LS tb (no reason really just to do it.) The ls throttle body that came with my engine didnt have the MAP on top, but it has the bolt holes.
Should I buy a map sensor for it? Or is it located on the firewall (92-95 civic)
