Map Sensor
Discussion in 'HYBRID -> BA-BB /CA-CD' started by 4drh22a, Mar 25, 2003.
  1. 4drh22a
    4drh22a Junior Member
    my ecu is throwing out a code 7 thats for the map sensor. i replace it and its still say code 7 i reset the ecu whats going on. thanks
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Are all your vacuum lines connected? Correctly? Did you mess with any wiring near the MAP sensor?
  3. 4drh22a
    im sorry i mean the tps sensor
  4. statiksol
    statiksol Banned
    did you ever take the tps off the throttle body? if so then it sounds like you didn't install it properly. just double check it.
  5. 4drh22a
    yeah i take it off and install a new one and the motor lag and the light will come on o yeah and it a h22
  6. dohcvtec_accord
    The left lane
    Did you check the voltage on it?
  7. AsiAnVenOm
    AsiAnVenOm Member
    onless you have tools for this, i would use two sowing pins and stick it into the wires and measure the voltage at key switch to on position...but dont start the car...when key switch at "on" position and have someone stop on the throttle when they step on the throttle you should see the voltage increase to about 4.5volts at wide open throttle....
  8. AsiAnVenOm
    AsiAnVenOm Member
    and at key "on" position you should have .5 volts
  9. AsiAnVenOm
    AsiAnVenOm Member
    if it's not at .5 volts at idle...turn the TPS sensor to get .5 volts
