DAMCOOLDAV
Member
http://b16a.honda-perf.org/Tech/vacuum.jpg this is for the vacuum diagram, and if you look at the top where the solenoids are........one of mine had the hoses taken off because of a/c(dont ask why) but i put a hose on ther eto block them both off, but does this need to be hooked up to something?? also i just put my intake on and i attached the hose to the valve cover and the top hose on the T/b that originally went to the old intake hose, but the air boost valve i just plugged with a screw is this ok?? Another thing, my purge cut off solenoid was not connected with anything, i had the a/c taken out so can i just plug those off with a hose goin to both of them, or do they have to be hooked upto something specifc thanks guys.
