messed up minime
Discussion in 'HYBRID -> ED-EF / DA' started by 90minime, Jun 17, 2009.
  1. 90minime
    90minime New Member
    i just got a 1990 hatch with a minime and it has some problems that i'm not sure about
    first off its a zc block with an i dont know head but its vtec i'm thinking a head off a 92-95 honda
    it has a pm6 ecu
    it has gas in the oil
    it smokes white like uncle bucks car
    my coolant level is still full
    it pulls fine unless i give it full throttle and it completely bogs down to nothing.
    the guy i got it from said the timing is off but it idles fine stuff so i dont know
    does this just seem like bad rings?
  2. lilsicsol
    lilsicsol i lOve my Ef sedaN..
    brooklyn...
    y waste time on a mini...
    sohc vtec motors are cheap..
    and trowing one in a ef its even easyR////
    check your tb sensor..
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Seems like a bad head gasket. Has the symptoms. Do a compression test and let us know how it goes.
    BTW, is the oil milky? The gas smell is probably from blow-by and/or bad PCV valve(just clean it).
  4. 90minime
    90minime New Member
    cause the car came with it.
    not sure what you mean by feels milky but when you rub your fingers together you can feel the gas in it along with smelling it.
  5. K2e2vin
    Raleigh, NC
    Milky oil looks whiter than it should normally be; like someone put milk in it.
  6. 90minime
    90minime New Member
    i would say yes then but not like super milky but i changed the oil right when i got it cause there was barely any in it and i have ran it for like 5 minutes since because of how much smoke there is
  7. K2e2vin
    Raleigh, NC
    Check/change your head gasket, it sounds like that's definitely the issue. It's not too hard to change; just make sure you get new head bolts(per Honda's recommendation) or ARP studs.
  8. 90minime
    90minime New Member
    yeah that is what i was thinking, and do i need to get a p28 and convert to ob1 or can i just keep running the pm6?
  9. K2e2vin
    Raleigh, NC
    It'll definitely run better with a P28.
  10. D16SiHatch
    D16SiHatch New Member
    yep ^ x2
