Hey I just bought a '91 CRX Si off ebay. It was supposed to need like a new tie-rod. However I got the car and it has a few other problems. I realize that w/o seeing the car yall may not be able to help me as much but thats ok.
First off, the cradle is bent. Only slightyly on the drivers side. The cv shaft on the same side is pushed inward. The half-shaft is rubbing against something, I think the cradle. The control arm is bent as is the sway bar I believe. The front end besides that seems to be fine. The frame is not bent in anyway that I can see, the windshield isnt broken and the wheel wells and everything are straight.
The car can* be driven and the engine seems to run great except for the ac belt that is missing. Also, the car has trouble going into gear and will sometimes come out of gear while being driven and will just decide when it wants to go back into gear. I suspect something may have been pushed into the shift linkage??
*I drove the car after aligning the tires as best I could. When I received the car the tires were facing each other (kinda pigeon-toed I guess you could say). It was only driven about a mile or so and then back to my house after having it looked over. The tires still dont face perfectly straight, one kinda faces inwards and gets drug a little bit.*
If anyone can tell me if those parts can be replaced w/o much of a problem I would greatly appreciate it. I had planned on strengthening the frame and replacing a lot of the suspension anyway. So I figure I got a lemon with this deal but I'm gonna try and make lemonade. Thanks a lot for any help and uh............ hondaswap.com rules!!!
