might sell rex... LOOK
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by formby, Mar 18, 2005.
  1. formby
    formby learning in progress
    91 dx i only want the long block....so it will have
    b16 cable tranny
    new avid b series mounts and shift linkage
    B&M short shifter
    rear battery relocation
    no name after market seats new/black...oem ones were broken
    mpfi hasport harness
    90 teg brakes
    2.25 in bent exhaust...no cat...18" resonator
    4-1 header
    no rust no body damage
    have all plastic...broken glovebox..
    just installed a walbro fuel pump
    91 si door panels
    93 gsr rims
    all the strut bars
    brand new 10 miles on tokico blues with H&R springs b 1.8-b 1.9
    ss brakelines
    new pads and rotors all around..
    shift light
    new teg radiator
    msd6a with blaster 3 coil
    pr3 spoon ecu
    maybe even 450cc new dsm from tunertoyz.com
    flat black
    http://www.hondaswap.com/forums/uploads//1...8_303_17405.jpg
    http://www.hondaswap.com/forums/uploads//1...8_303_13129.jpg
    http://www.hondaswap.com/forums/uploads//1...8_303_18222.jpg
    i love this car but my girls might buying a lude and im keeping the hatch so no need for 4 cars..... the lsv is going in the hatch.... all you need is a long block!!!! i'm looking for 2.5k neg
  2. formby
    okay i might sell it with the long block....new everything.i mean every thing
    water/oil pump (gsr) new oem
    timing belt kit
    new oem full gasket set
    .020 over bore
    pr4 pistons/rods
    arp head studs/rod bolts
    block guard
    99 b16 head
    99 b16 intake cam/99 b18c exh cam
    obx cam gears 5 bolt
    new oem ls crank kit
    all new acl bearings
    lightened oem flywheel
    excedy stg 3 clutch/ pressure plate 700 miles bought new
    str cam oil plug
    new distributer king b16 dizzy w/ msd cap for the 6a
    rebuilt alternater/ starter
    all new hoses (all of them)
    type r oil cooler
    ......runs 14.9 with a bad suspension..@96.9mph. and im not that great at drag racing yet..i have all recieps off all work done and parts bought...also included a crx shop manual oem honda 300+ pages....will try to link up a vid later...(of car)
    4.5k with engine runing perfect...my baby doesnt hit vtec every day because i dont drive it every day...garage kept
  3. Taco15
    Tallahassee Fl
    alright where are you located? does the car run now? A guy just left my house asking for a crx. I might have some him buy it if your close enough. Im in Tallahassee FL.
