Mini me Comparsion Ratio
Discussion in 'Engine Building' started by calvin, Oct 8, 2002.
  1. calvin
    calvin Senior Member
    NETHERLANDS
    I want to know how much boost a mini me setup can take, if tune correctly.
    Thnx
    CR 9.5 or so.
    How can u convert psi from a compretion test to something like 9.2:1
  2. CRX-YEM
    Wallingford, CT
    Well you can't simply ask how much boost can I run. you need to be clear on your desired application, is it for autoX, Drag Racing, Just for some more poer on your daily driver. Along with a proper choice in which turbo to use, you'll need to do some engine build-up. some forged pistons like JE, Stronger Rods, Re-Sleeve the cylinders, an ignition system, and other things which will make the set-up less prone to failure.
    To make it simple you can't just slap a turbo on a car and say I wanna out this much boost into it.
    Article on Compression testing
    http://www.hondaswap.com/articles/viewer.php?id=34
