i have a sohc zc 1.5 bottom end with a y8 head when i start it it dieds acouple times as i start it the car shakes as if the motor is about to blow if i give it gas it dieds right away once it goes over 1000rpm it starts to jump up n down once heated up the car runs stronger then the old 1.5 head alot more tonque at lower rpm but feels like its not getting as much gas i have a cam gear ,b20 injectors ,intake ,header ,full 2.5 pipe endding at a type r muffler i played with the dizzy n cam gear got the car running alittle better i dont know what dizzy am using it was the dizzy that made the car run better then the others i had around i bought a brand new z6 dizzy but the holes didnt line up feels like the car need more gas n it already drinks alot of gas motor is in a 93 civic dx i did not do any wiring still running stock 1.5 ecu plz someone help want me car running mint
