mini me help??
hatukazi
ambitious...but rubbish
anyway my best friend and I are nearly finished completing his mini me swap on a 91 crx Si.
before it is finished we need some help please.
done so far is;
head and intake manifold from 98 HX installed w/ 91 injectors,
ECU from 98 HX w/ rywire obd0 to obd 2a conversion harness.
questions are which timing belt to use? crx belt is too long.
which distributor to use? we have both. (98 hx and 91 crx)
how many 02sensors? I cant remember when I stripped my HX,
pleasse help, we are almost done and want to haer this car rip!!!!!
I can tell you right now to use the obd0 dizzy so it will plug right into your harness. Just wondering why you went from OBD0 to OBD2 and not OBD 1. OBD1 is much more tuner friendly.
all the parts came off my 98 civic HX that the insurance co. totalled cuz some jackasses crowbarred my trunk to get my subs.
if my dad hadn't borrowed out his bobcat I would have pulled the whole engine and tranny but.....
the hx ecu works really cool because it can hit VTEC at partial throttle at 3000 RPM.
also dont remember if I asked about the throttle body(also from HX, waaaay bigger that Si) will it work or would we have to re-wire it?
