Mini-me Trouble
Discussion in 'HYBRID -> EG-EK / DC' started by SolStopper, Feb 6, 2003.
  1. SolStopper
    SolStopper Junior Member
    I need some help with a mini me. It's a 99 d16y7 with a 98 y8 head. we got the head on the block it runs fine but having trouble wiring vtec. We don't have the ecu but I've read about something called a "rpm switch." I was wondering if anyone could tell me how to make this work....
  2. HondaCivic95
    HondaCivic95 Junior Member
    The risk on using an RPM switch is that you can fry the VTEC selenoid plus you're not getting the fuel maps that the engine needs when going into VTEC- best bet is to get the ECU for the EX, Im not sure about which wire goes were in the '98 ECU but here is what I got for the '95 Ex, at least you can have and idea and you can search it one the Net...
    "ok.......now on to wiring vtec
    you need the plug on the vtec solenoid with the cut wires......there should
    be 2 wires from the bottom harness......and 1 wire from the spool top
    harness......
    1st harnes( 2 wire one).....
    1 blue wire- oil pressure sensor
    1 black wire- ground
    extend the black wire and run it straight to a good solid GROUND
    blue wire should be extended through the fire wall straight to D6 on the ecu
    2nd harness(1 wire one)
    1 green w/yellow wire- vtec solenoid
    run a wire from the green w/ yellow wire all the way through the fire wall
    to A4 of the ecu
    now....thats 1 wire going to ground....and 2 wires going to the
    ecu.........now...........there should be NO......I repeat NO check engine
    light......unless you didn't hook up vtec rite............."
  3. Havok
    Havok Senior Member
    Florida
  4. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    Ok, question.
    D15B7 Block
    D16Z6 Head
    D16Z6 Trans
    D16Y8 Harness
    P28 ECU
    Yea, does that work? Or is there an easier way to do it electronically?
  5. Havok
    Havok Senior Member
    Florida
    Why would you use a Y8 harness? Get the Z6.
