Monster Engine
Discussion in 'Engine Building' started by markie, Feb 24, 2003.
  1. markie
    markie Senior Member
    im gonna but a itr head on a ctr block it will yeild around 300 hp allmotor when im done with it ill keep ya posted with pics
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    might i just inquire as to why??
  3. SolReaver
    SolReaver Senior Member
    haha good luck on that man :rolleyes:
  4. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Hope you're not planning to drive it on the street....
  5. pills_PMD
    New Albany, OH
    the only real difference in the CTR block from a regular b16 block is the pistons. they will make the C/R 10.8:1 with an otherwise stock setup.
    i would take a b18c block and put the CTR pistons in it and use an ITR/CTR head... the only real difference being the valvetrain.. which i assume you are going to change if you plan on making anywhere near 300 whp all motor...
    so ... think long and hard before you start this project because it sounds like you just decided it would be a good idea to combine ctr/itr parts and hope for power... but you have it kind of ass backwards.
  6. markie
    yea but the ctr block im sure is alot more durable then a stock b16 and yes im doing it all knife edgeing extrude honing alot of stuff and no street drag and autox only
  7. pills_PMD
    New Albany, OH
    disagree. honda did not engineer two separate blocks with the same bore and stroke and make one stronger?? not cost effective. a ctr block is only as good as the parts in it. the pistons are better. since they have a higher compression.
    rethink this and save yourself money and go faster .
  8. markie
  9. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    you will also need some kind of nitrous setup too. besides i think you should check out the compression calculator herecompression calc.. cause if you want real n1 power your gonna need serious compression.
    don't you think if it was easy or cheap to get 300 hp all motor we would have seen it already in the all motor drag cars? and they would probably be running on bored h22s.
    sorry hope i didn't blow the welds on your intake manifolds.
  10. civicSiR1
    civicSiR1 Senior Member
    I have EG 6 with Toda/Spoon fully built all motor.....and it's only 262HP......i'm running 11's though....i spent hella time and money on it......did hella research....for tht project, good luck....cuz mine wasn't even a conversion setup, just a B18C5......
  11. cws13
    cws13 Senior Member
    Athens,GA
    Last time I saw specs on Loofsky's motor (and it's been a while) he hadn't hit 300 whp yet with a bored H22 running at over 16:1 compression ration using sick amounts of NOS to keep it from detonating. (I know that doesn't sound right but he had this HIGHLY tuned setup where that much NOS cooled his mixture enough to run it.)
  12. pills_PMD
    New Albany, OH
  13. B16
    B16 Super Moderator VIP
    yay area, CA
    sorry sir, but you are wrong... the ctr block (b16b) is the same block casting as the b18c5/r
  14. pills_PMD
    New Albany, OH
    i stand corrected then... are you sure?
  15. pills_PMD
    New Albany, OH
    you know.. i might have to disagree on this one:
    http://www.hondaswap.com/reference/index.p...de=engine&id=26
    why would honda make a 77.4 mm stroke in a block that is more than capable of something like 87 mm.
    it doesn't make sense. and if that is wrong, if you were to use the b18c1/5/R block with the CTR pistons the compression would be like 12:1.
    but the b16b has a 10.8:1 compression which is achieved by using a 77 mm stroke and an 81 mm bore
    i may be wrong, but my logic seems right to me
  16. B16
    yay area, CA
    yes, positive... did a quick search on google and picked out this one
    from http://www.teirney.net/whatsnew/Home.htm
  17. B16
    yay area, CA
    yes, if you put ctr pistons in a b18c1/5/r you will have a compression ratio of 12:1, i think it is slightly higher than that. with the shorter stroke of the b16b crank in that block, and shorter rods, the pistons do not come as close to the head, which is how the b16b has a CR of 10.8:1, this is also why when you put CTR pistons in a b16a block, you get about 11.6:1 CR.
    EDIT:
    found this reference on that site too..
    http://www.teirney.net/civic/B16AReference.htm
  18. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    It is the same casting as the B18C5/r. Carboy (the Japanese car mag that my girlfriend brought me from Tokyo) has all kinds of stroker kits for the B16B that are basically the ITR rotating assembly, and they specifically say that these kits are for the B16B onlly. It makes perfect marketing sense. You have a block that you know is solid, you want to use it on this new car, but you don't want this new car to out sell the car the block came from (it's the same reason we haven't seen the real Civic R yet, Honda doesn't want to out sell the RSX-S with it maybe there is hope if we ever get the DC5R here) so you de-tune the engine going in the new car.
  19. B16
    yay area, CA
    i wouldn't really call it "de-tuned" the b16b is basically a destroked b18c. it has its advantages and dis-advantages with the b18c
  20. lsvtec
    Maybe not de-tuned, but it has less power so I figure it is detuned. What are it's advantages over the B18C spec R?
