monte carlo help
Discussion in 'Other Vehicle Discussions' started by AHHVTEC, Jan 21, 2009.
  1. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    im helping my grand pa fix a 1997 monte carlo. the mph gauge dont work. so we bought all new vss and even tried a new gauge cluster with no change.but oddly we found that if you unplug the after market radio the cluster will work but as soon as you plug it back up its dead again. im clueless on this one.
  2. E_SolSi
    sounds like youve got a short somewhere in the wiring debacle
  3. AHHVTEC
    Alabama
    yeah thats what i was afraid of
  4. sevenhillsbilly
    sevenhillsbilly New Member
    its either the short or you may have to check the spedo sensor. or even a fuse can do that i had that happen before
  5. capricefrk013
    capricefrk013 is waiting for summer
    NE OHIO
    Did you fix this yet? I have seen this before on the exact same car. There is a green with white stripe at the radio harness. It is probably grounded. The one I saw is that the dumdum (the owner) hooked it to a speaker wire so when the volume was turned up so did the MPH's on the dash. So find that wire and make sure it aint grounded somewhere on the radio or in the dash. Hope this helps.
  6. AHHVTEC
    Alabama
    ahh yeah forgot to up date they had the radio wired in to the cluster harness lol
  7. capricefrk013
    NE OHIO
    Thats what I thought it was. lol. Glad you got it worked out.
