motor at an angle.
Discussion in 'HYBRID -> EG-EK / DC' started by 93hondaproj, Feb 23, 2009.
  1. 93hondaproj
    93hondaproj New Member
    EPT
    First off just like to say i have registered to the site awhile back just havent really posted much, been reading and a lot of good stuff here :thumbsup: . So i just finished up a gsr swap in my 93 ex, I used a manual tranny mount from i believe a d-series and i have noticed that my engine is a little higher on that side and i dont understand why. Do i need different studs or did i forget something as to why its lifted higher on that side ill post a pic later.
  2. MthaFuknGreen
    Lodi, CA
    do you notice any difference in the mounts?
    did have you drill holes for the new mount?
  3. eg6sir
    either a mount is toast or you've used the wrong mount
  4. Briansol
    you should use the integra mount, not the civic mount.
  5. |Chaz|
    |Chaz| Well-Known Member VIP
    x2 D series mounts are not compatible with B series motors.
  6. 93hondaproj
    EPT
    No i didnt have to drill any holes and its still a good mount, no sag.
  7. |Chaz|
    You can't use a mount from a d series to do a b series swap, didn't you notice mine and B's posts?
  8. Briansol
    you will break axels left and right (no pun intended) if you don't get a b-mount in there.
  9. |Chaz|
  10. 93hondaproj
    EPT
    Found out why its an angle, my car use to be an auto and now i have a manual gsr in there and because it was an auto the mount on the chasis sits higher, so i have to purchase an aftermarket hasport or innovative which is made with the longer material needed.
  11. je power
    je power New Member
    my house
    my bro had the same problem in his teg and it was a auto and he swapped in the manual trans
  12. 93hondaproj
    EPT
    Yeah so i ordered the mount and that should take care of the problem ill let you guys know, so maybe next time if someone else has the same problem and dont know about it.
