I actually have the same problem, but I have a B20 motor. I'm not sure if they are the same for all b-series or not, I was thinking maybe just go to a junkyard and see if you can pull one off. Did you need just the mount itself, or the bracket on the engine? Because I know that the bracket is actually what the AC compressor mounts to, so it kind of has a dual purpose I guess, and there's a bolt that goes from the bracket through the mount. Anyway, if you just need the mount itself, then you should be able to find an OEM replacement on ebay or something. Hope this helps.
