I just want to be sure which mounts I need to get from an integra for my 93 civic dx. I am putting in a b16. I just need the bracket and rubber labeled 7 and 10 from this picture correct. The rest of the stock mounts will work?
I am not sure. It is a b16a (japanese model). Are you asking because of the mount that has two or three holes? And I just need the bracket not the insert correct?
If it is a 95-95 JDM B16A motor then you can use your stock mounts & the rear T bracket the motor came with. Otherwise you can use the rear T bracket from a 94-01 MT Integra.
Is there a way to identify the t-bracket. I have one that came off a 98 ex that I pulled my b16 from. Is there a number or something distinct that I can use to tell if it will work?
