Motor mounts
hondaflr
Member
witch motor mounts do i use in 95 accord with 94 engine, at this moment im using factory motor mount from the 95 accord, and the driver side is being held down by 1 bolt, the others dont fit. and im getting scared.
You should be fine with the setup you have. You can either:
1. Use the full Prelude mount, and grind it down to fit.
2. Use the setup you have, and tap a new hole in order for the second bolt to fit.
Wouldn't worry too much about it, though.
:concur:
Don't overthink it. The 94-95 Accord mount is skinnier from stud to bolt than the Preludes and 90-93 Accords. My 92 Accord mount worked perfectly, with no mods.
