Motor Oil During Breaking In Process
Discussion in 'General Tech and Maintenance' started by NoJokE, Mar 27, 2003.
  1. NoJokE
    NoJokE Senior Member
    Which do you recommend? I know that it has to be natural and not synthetic. Any particular brand that anyone cares for. Should i use the OEM Honda Motor Oil even though i do have aftermarket pistons and a sleeve job?
  2. beau_safken
    beau_safken Senior Member
    Seattle, Washington
    Just run Dino oil and change it after the first 50 miles or so. If you are breaking in a fresh newly built engine the extra metal will be coming off and getting all over the engine within the first 20-50 miles. If you dont change the oil that fast, you run the risk of getting the trace aluminum adhering to your engine parts and screwing up your build... Dino oil Only for the first 2k miles on the engine, after that the engine parts will be broken in so you can run the slick stuff then.
  3. NoJokE
  4. machine
    machine Banned
    houston tx
    Dino=dinosaur=natural
  5. NoJokE
    all right thanks
  6. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    The mileage that you need to run natural oil for is determined by the parts you used in the build. Mine was broken in by 1000 miles. I am going to synthetic this weekend.
  7. E_SolSi
    best practice .....
    fill it with regular oil
    start it
    run it for about 20 min or so (get it to full temp)
    replace the oil (regular)
    start it
    drive it for about 500 miles
    drive it for the rest of the break-in
    replace it with whatever the hell you want (regular or synthetic)
    ive seen engines get FUCKED UP by not swapping out the first oil.... (happened at the shop to a $8000 porsche 4 cam engine for a '59 356 ... that was not a happy day for that mechanic)
  8. chevy302dz
    chevy302dz Senior Member
    :werd: :withstupid: The other thing to remember is while in the breakin period DON'T BEAT ON IT because if you do everything else won't matter
  9. hybridsol
    hybridsol Senior Member
    ohio
    i've heard after the frist oil change that you are supposed to rag on the car for like a couple miles to get everything seated and stuff
  10. lsvtec
    No, like chevy302dz said,. don't beat on it. In that first 20 miles I did a couple of 1/2-3/4 throttle pulls to 4500 RPM in 1st, 2nd, and 3rd. That was as hard as I rode it. You don't want to be running the engine out to red line.
