motor prep questions
Discussion in 'Engine Building' started by 94_gs-r, Jan 17, 2007.
  1. 94_gs-r
    94_gs-r can you say 260 whp N/A??
    im taking the motor out of my integra gsr, are there steps i need to take and shit to plug or do i just take everything apart and pull it out. i have all the bolt on stuff out and the drive axles out. what steps should i take?
  2. 94_gs-r
    so there are steps then... damn. already pulled most the stuff only thing i havent done is depressurise the fuel line
  3. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    you dont need to depressurise anything....
    Just take the damn thing off... nothing's gonna' happen.
    dont forget the heater hoses in the back, and the o2 sensor(s)
    I always seem to forget to take those out and end up fucking them up.
    good luck!
  4. GSRCRXsi
    MD
    helms ftw!
  5. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    true to marking, are you going to give it to me when you get it out?
    there isn't anythign special just make dure you rememrber everything when you put it back in. Do the engine mounts last, obviously.
  6. 94_gs-r
    haha almost tried to pull it with shift linkage
    on the intake, all of the vacume lines are those needed or are they just for the butterfly valves? im removing the butterfly valves
  7. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    Don't forget about the ac high pressure
  8. klyph
    klyph Dismember VIP
    North Pole, AK
    hehe, make sure to point it at your face when you disconnect it.
  9. 94_gs-r
    ac has been off for months
    reason i ask about the cacume lines is because they go to the butterflies dont they?
