Mugen! Spoon! Reprogram Info!
sykeghatch
I was wondering if any ECU REChipped PRogramers out there know the
Spoon Program
SKUNK 2
Jun
or
Mugen Program
i am very curious on what the information is on it..
If not does any ECU reprogramers know how to do it? if so let me know I may buy one
CUz I heard u can get SOHC ECUS and reprogram them to DOHC MUGEN SPEC..
So let me know thnk you
what do you have done to your car to warrant more fuel? more redline? higher VTEC?
if you don't, you don't need a chip. chipping your mostly stock car with I/H/E will probably slow you down and run rich as fuck and get shit for gas mileage.
that said,
skunk2 = mugen = spoon for the most part. they all raise the vtec point and rev limit and make you run rich as fuck.
Spoon Program
SKUNK 2
Jun
or
Mugen Program
Skunk2 is a direct ripoff of the Mugen program.
Spoon is less fuel rich, and modify's the ignition timing.
Jun has wierd timing curves, and a wild fuel curve. I don't recommend using it unless you have BIG cams.
Unless you have the mods to warrant a higher redline, I don't suggest it.
Is this what you wanted to know? Or is there more to your question?
Yes, I can modify SOHC DX (some) and EX ecu's to DOHC VTEC specs minus the Knock sensor and IAB control boards.
