My Car Started But I Have A Jumpy Idel
Discussion in 'HYBRID -> EG-EK / DC' started by BlackDelSol, Feb 18, 2003.
  1. BlackDelSol
    BlackDelSol Banned
    i finaly got my mini me to start but my idel is a little, well alot of, jumpy idel. it is going from 1 grand to 2 grand and back and forth rapidly. what would cause this?
  2. mwvnos
    mwvnos Senior Member
    SC
    u have the right ecu? timing could be off maybe, or could be a vacuum line...i had that prob to woth one of my freinds cars...it was vacuum line
  3. BlackDelSol
    BlackDelSol Banned
    it was happening befor i did my head swap, i just figeured that wile i have all my stuff still out i would take care of this too.
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    did you change the TPS sensor at all?? or is it the same one??
    vac lines or sometimes... the intake manifold gasket can be leaking too
  5. BlackDelSol
    BlackDelSol Banned
    brand new intake gasket. and all vacume lines are good
  6. pills_PMD
    New Albany, OH
    tps sensor?
    .5 volts closed... 4.5 volts WOT??
  7. BlackDelSol
    BlackDelSol Banned
    if i put a differant throttel body on instead of messin with it. do you think it will fix it. i have 4 extra throttel bodeys layin aroung in my workshop.
  8. pills_PMD
    New Albany, OH
    i doubt that will fix it... if it is set from the factory... it's probably good
    try the iac valve... is that plugged and working properlY??
    is the screw on the TB letting to much air by?
  9. BlackDelSol
    BlackDelSol Banned
    this may sound dumb, but that is an iac valve, i that the one on the bottom of the TB? i heard that if the plastic screw backs out some it could couse this to happen, is that true?
