I have fuel, air, correct compresion. Something wierd happened today I took the battery cable off let it sit for about an hour and when i put it back on it fired right up! After it ran for a little I turned it off and then it wouldn't start again! I've heard two things the injectors need the resistor box but then I also heard that integra injectors don't need the box and can have straight 12v power. Right now I have and the resistor box plugged in and it runs fine.
