My eg wont rev pass 2000rpm???help needed
jundowg23
I just bought and eg 94 and it has a ZC jdm engine........but for some reason it wont rev pass 2000 rpm...it will hit 2000 rpm but then it will drop back....i need as much as help as i can get so i would appreciate ur help!!!!so if u know of anything let me know???
Welcome to HondaSwap!
There is ABSOLUTELY NO NEED to triple post your question. That just annoys people who would otherwise take time to answer you. Your other threads are now locked. Don't do it again.
As for your problem, I would start by checking to make sure you have the right ECU, then make sure all your sensors are hooked up, then make sure that your ignition system is good.
