cxjon
ok i am on a whole thing to make my car look stock on now its moving on the engine.
my plans are as fallows:
*get a sirII air box or a 99si air box with k&n drop in
*install my 60 mm tb that i had for years
*find a heat sheild that could cover up my header
for inside my motor i am getting a a set of p29 pistons/rings, d15b7 oem head gasket, zex cam, arp head studs and a hondata intake manifold gasket.
for tuning and other i am getting a techedge wideband o2 http://wbo2.com/ and i am tuning the car with uberdata. a bunch of friends of mine are using uberdata along with the techedge o2 so it makes since to use all the same shit. my cr will be in the high 11's. i have a spair y8 head that might get some work done when i can afford it.
for the inside i need a cluster with a tach in it and i also need a heat contorler with the ac button on it.
tell me what you guys think
I love my sohc
I love my sohc
