There we go. We are already to a problem and we have not even started! Just goes to show how many problems prelude motors really have.
Problem #1: You can't bore and hone a prelude block, its FRM. You have to sleeve.
Problem #2: You can't put an aftermarket piston in a FRM block. You have to sleeve.
Problem #3: The motor has 2 very heavy balance shafts in it...think about why that is. Its because the motor is horribly unbalanced and vibrates horribly. So they needed literally POUNDS of metal in it, in the form of shafts to limit the vibration.
Problem #4: When the turbo comes on the motor, its going to exponentionally stress all the parts, causing WAY more vibration.
Problem #5: Hydralic tensioner is a HORRIBLE design. Under heavy load it will go: tight, loose, tight, loose, tight. very fast...causing even more vibration.
Problem #6: the oil pump can;t take bad harmonics and will break under too much vibration, causing you to lose your entire motor.
Problem #7: You can't use a H22A ECU to tune your car any good.
Problem #8: The transmission is by far the worst Honda makes and it can't shift at high RPM's at all, causing more misshifts than any other tranny I can think of, that leads to massive amounts of bend valves, which can cause you to loose your entire motor.
Problem #9: The labor rate for working on preludes, is probably 175%-200% that of a B series.
Problem #10: the parts for a prelude cost alot more, and there are alot more parts.
Problem #11: The stock prelude pistons, any kind, have the weakest ring lands of any Honda piston that I have ever seen, and cracking them is almost a certainty under boost from a turbo.
And then when your mentally over the 11 problems I present here, compared to say a single cam, or B series motor, you have a multitude of other problems that are annoying as well.
The only reason I like the Prelude motor, for myself, is because I know how to handle all of the above problems and can maintain it perfectly. If you can handle those problems, then turbo it, it will be really fast.
Just get the heaviest crank pulley you can find and put that on. helps the harmionics problem.
Jeff
