My rear hatch is leaking, help
Discussion in 'General Tech and Maintenance' started by projectxspeed, Mar 13, 2004.
  1. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    I was cleaning up my 95 integra today. When I opened the hatch I noticed the floor was wet. I removed everything from the back, and I found a small puddle of water in the spare area. It looks like it is coming in from the back. Has anyone run into this problem with their integra? Any suggestion on how to attack this problem?
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You attack it with new seals from Honda. Hatch (almost all of them) develop this issue over the years, it's the nature of the design.
  3. projectxspeed
    New Hampshire
    So I take it this problem I am experiencing is a common one for the age.
  4. xj0hnx
    C.C.TX.
    That and rusty rear quarters are like death and taxes for Hondas.
  5. projectxspeed
    New Hampshire
    O its true. I have those already. Lucky for me I found a guy who has been doing body work for 2x longer than I've been alive B) . His work is awesome and it does it for a hobbie, aka it does it well and cheap.
  6. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    There is also styrofoam gaskets around the taillights that cause a problem. Have a friend spray the back of the car with a hose and sit in the hatch with a flashlight and look for leaks.
  7. projectxspeed
    New Hampshire
    Thanks I will try that before I go crazy on the new oem seals. I think it is coming in from the back so that just might be it
  8. whiteLS
    whiteLS Senior Member
    Sarasota, Fl
    yea i had the same exact problem in my 94teg, i replaced the hatch seal and that fixed it
  9. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    I have a 91 integra-ive never had any problems with water in the hatch area. Ive been having a problem around the ECU area(passenger side upper floor. This has been concering me ya know with my cars electronic brain getting wet. anyone know whats leakin?/ what to replace? my amp power wire runs in in the area- but the hole isnt that big and leads to the engine bay so I dont think it is that.
    I just thought Id post it in here because we are on the topic of leaks and the other person got a answer.
