My SiR2 96 DX
Discussion in 'HYBRID -> EG-EK / DC' started by honda_power69, Nov 10, 2002.
  1. honda_power69
    honda_power69 Member
    I finally finished the swap. Worked out all the little bugs and fixed all the little things we happened to leave loose and looked over somehow. I do have a question though, the motor seems to be idling a little rough and sometimes feels as if its missing when vtec is almost ready to kick in when im giving it WOT. Mods so far are (for reference): AEM CAI, custom 2.5" header-back exhaust system (no cat), MSD 8.5mm Superconductor wires, NGK Laser Plugs, Mugen clone chip with 5700 rpm vtec x-over. I know that it might be the chip causing it run run a little too rich for the VERY mild mods I have done. Just feels as though its cutting out when I start getting into the higher revs at WOT. Any suggestions would help a lot.
  2. Havok
    Havok Senior Member
    Florida
    Try 93 octane and run colder plugs, my car ran REALLY rough when I was using 87 octane.
  3. honda_power69
    actually i run 98-100 octane in it already. 93 and octane boost (non-methanol) at every fill up.
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I think that you would be better off running 93 without the octane boost. Your modifications don't include anything that would require that kind of octane. Do you have an ECU without a chip to try?
  5. chet
    chet Senior Member
    st petersburg, florida
    i doubt very seriously that you have a problem with the fuel itself.
    do you have any CEL's?
    chances are you have miswired something or have incorrect timing, or something to do with ignition.
    ignition, fuel delivery, wiring...one of those
  6. phunky.buddha
    Dallas / Fort Worth, TX
    The Mugen chip runs a LOT of fuel... it's probably the root of your problem. Get that car on a dyno, then wire up a VAFC and tune it! Or you could go Hondata as well.
    :D
  7. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    hell yea. the mugen clone's run rich as a motherfucker. i had one in my sol for a while, and my a/f gauge was buried RICH the entire ride, partial or WOT
  8. Jeef
    Jeef NO MA'AM Moderator VIP
    Your octane booster is only boosting it up points, so you're really running like 93.8 not 98-100. Save your money.
  9. pissedoffsol
    i agree with everything above.
    the mugen chip is IMO way to strong for a stock b16 internally, which you have. lean it out with a vafc or get a hondata system and get rid of that chip.
    91-93 octane is fine for a b16. anymore and you are doing yourself no good
    jeff is right about those boosters-- the boost points, not wholes.
    And pull the codes- if you are getting a burp, chances are the ecu recorded it.
  10. ALLJDM
    ALLJDM Senior Member
    Tampa, FLorida
    I also i agree, but how long was the motor sitting before you installed it. Maybe you should drive it on the highway to blow some of the carbon out of the motor.... But you'll definatly need to dyno the car to really dial it in!
  11. honda_power69
    okay, after test driving today and getting a few other opinions from the guys I work with...we all agree with what you guys have said. its the ecu. Its not that its actually cutting out, its more like its popping and cracking and feels like its loosing power in and out as I give it gas. It backfires like a mofo as it is...so I feel I wasted my money on the chip. I would definately like to go to a hondata system after all the good reports I hear repeatedly on here. do they have prices listed on their site? also, the nearest dyno to where I live is still like over 100 miles away, so would I be better off getting the hondata and tryin to tune it myself on the dyno or is that something the shop would more than likely know how to do? (sorry, I have no experience what so ever with dynos. I live in Morehead, Kentucky, to make a long story short...redneck usa.) Thanks for your help guys.
  12. HondasHateMe
    HondasHateMe Senior Member
    Dayton, Ohio
    :werd:
    Where is the nearest dyno u know of??? I'm in southern Ohio, some of my buddies go to MSU. I doubt many shops around here tune Hondata, I don't know of any. I'd try a stock ecu tuned with a vafc route, tho dyno time would be more precise.
  13. honda_power69
    well, a couple guys I've talked to that tune race cars and shit said they had to go to Louisville. I can't remember the name of the shop...I'll have to ask and find out. I'll let ya know. By the way, where u at in southern ohio? not like ironton or ashland or huntington or anything is it? I know a few guys from up around there.
  14. pissedoffsol
    hondata.com has prices listed... you can buy from c-speedracing.com and other places all over the net.
    get the system, hook it up - run a base program.
    drive your ass to the dyno place
    tune it
    burn a new eprom chip for YOUR car drive home.
    lather
    repeat if desired
  15. B16
    B16 Super Moderator VIP
    yay area, CA
    i have the mugen chip running my b16 now, and just recently had it tuned with the vafc, and yes it runs rich as shit! but, i did not get the same symtoms you are getting with mine, mine ran just fine but was very rich. do you have a friend with a stock vtec ecu you can use? plug that in and see if you notice a difference (besides vtec and rev limits being different)
  16. honda_power69
    okay, i'm beginning to think theres something very wrong with my timing. These symptoms seem to be progressively getting worse. At least, its worse now than a few days ago. Its to the point now where it almost wil not accelerate above 3500 rpm if i give it even a little more gas than normal. Im going to set the base timing tomorrow and check out my spark timing...I'll let you guys know what happens.
  17. honda_power69
    o, i almost forgot to mention...the damn tranny is really taking some getting used to lol. cant get used to it being geared that low at all...cruisin on interstate in 5th runnin almost 4k, definately a change for me.
  18. pissedoffsol
    sounds fuel related to me dude.... if you press it, and you go no where... fuel or dizzy...
  19. S2easy
    S2easy Junior Member
    pressing gas and going nowhere... my S2k does the same thing... once i reach the VTEC point, the engine starts growling loud as hell, but the car doesnt react, and my RPM's start bouncing up and down.... wut do u guys think? when i go back to the dealer, im gonna tell him that it might be a fuel injection problem, atleast thats what i think it is.... :(
