No no, it was regarding the PCT argument. PCTs in GSR are around 13:1 but that's not far off(small differences are normal presuming variances in measurement), but that also wasn't part of the argument(the thread was just to show how CH can severely affect compression ratio).
What compression you run has more to do with it the overall compression figure, as combustion chamber shape/bore makes a huge difference. The motor I'm building right now, I'm actually aiming for 13.9-14:1 compression(pistons are pretty much flat top/slightly dished). Theoretically, a smaller bore helps control detonation better hence able to run higher compression.
