Need a smaller power steering pulley....rubbing on headlight
CK4500
I resently comepleted a block swap on my EK hatch.
I had a B16A2 and swapped out the block for a B18C1. I am running a Vortech Supercharger, and I ended up having to re-engineer all of my supercharger mounts.
With the added height of the new block, my power steering pulley is in the way for my to put my headlight back in. It will make contact with my headlight adjustment gears. So I can't just rework the back side of the head light.
I'd like to try to keep my power steering.
Does anyone know of a smaller pulley that will fit?
Look for some underdrives- might also want to look into lowering your engine mounts to drop the engine a bit too if you want to go the cheap route.
Washers, custom spacer... it's a bit "ghetto" but it can work.
