need advice
Discussion in 'ECU's, Electronics, and Tuning' started by JeDi PiMP, Jul 31, 2003.
  1. JeDi PiMP
    JeDi PiMP Junior Member
    Ewa Beach Hawaii
    I have a b18c1 in my 99'00 civic, and im running a 99' si ecu...any pros and cons??
  2. word
    word Senior Member
    if you'll using the b18c1 intake manifold then you shouldn't be using the b16a ecu.
    i dont know of any pros.
    cons: b18c1 has secondary butterly, using the b16 ecu you will be losing mid range torque. also i'd imagine the b16 ecu'd be supply less fuel than the b18c's.
  3. ngq
    ngq Member
    fuel map is not the same u are not getting the full power .try p72 its alot more
    powerful. i tried ctr ecu (pct) on my itr motor & it killed the power. good luck.
  4. b16ahatch
    b16ahatch Senior Member
  5. JeDi PiMP
    Ewa Beach Hawaii
    YOu guys are right , im not using the full potential of my GSR. I've done the swap in april and everything else is cherry, but my engine light has been going on and off everytime. We read the code at being too rich or too lean. Here's the thing, i have a GSR ECU but it dont connect to the harness... :angry: So if you guys know how to wire it up for me it would be cool.
  6. JeDi PiMP
    Ewa Beach Hawaii
    Oh yeah one more thing...would it be better if i hook up a v-afc to it??
  7. word
    word Senior Member
    what year is your gsr ecu from? you need one from a 99-01 integra Gs-R. anything else will not plug in you'd need an adaptor which will run you around 100-200 bucks.
    and yes vafc is always cool looking ;) , plus if you decide to do further modifications it'll increase the tunability of the motor.
  8. JeDi PiMP
    Ewa Beach Hawaii
    its a 99 GSR..where would i get a n adaptor
  9. JeDi PiMP
    Ewa Beach Hawaii
    Also the 99 Gsr ecu plugs in except for one...the plug that does not fit, what wires are those??
