Yea so my brakes went out totally. No pedal response whatsoever. So I think I am going to purchase stainless steel brake lines, and use synthetic brake fluid. DOT3 Prestone.. unless you guys know of better brake fluid that is dot 3. Anyways, I need ceramic pads and SOME kind of DISCS that fit on a civic DX. In this case, what do you all recommend for performance discs or blank discs that are DIRT CHEAP? Brembo blanks??? And if so, where should I purchase the discs? AH YES... I need calipers too... what kind of calipers should i get? is there some that are slightly better than stockers at high speeds? thanks a lot whoever responds...
