Need d16a6 front upper motor mount block bracket.
Discussion in 'Parts: For Sale/Trade/Wanted' started by Angus, May 14, 2008.
  1. Angus
    Angus New Member
    Kansas City
    I discovered a hicup in my block conversion. I am using a d16a6 block to replace a blown d16z6 block. Once bolting the motor mount brackets on I discovered a difference in the bosses on the blocks. Does anyone have a d16a6 front upper motor mount bracket, the part that bolts to the block?
    Thank you much, Angus
  2. itrsleeper
    itrsleeper New Member
    i got a couple d15 mounts not sure if its what your looking for tho.
  3. Angus
    Angus New Member
    Kansas City
    Not sure either? I was told the block swap was more or less direct. What vehicle did they come from, maybe I can cross reference with the dealer.
    Thanks
  4. Angus
    Angus New Member
    Kansas City
    Just checked with the dealer. The z6 and a6 mount are different. They are shooting in the dark since I do not know the exact car my a6 came out of.
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the a6 came from a civic/crx 88-91
  6. Angus
    Angus New Member
    Kansas City
    Cool, now to find that donor or cheap part.:)
  7. itrsleeper
    lemme go check in the garage, i got an old d15b that came outta a crx around that year and a d15b8 that i think came outta 94-95 civic.
  8. Angus
    Angus New Member
    Kansas City
    Will those blocks be similar? Im no expert so I was surprised the difference in the d16a6 and d16z6. I know most people doing a mini-me start with the a6 and dont run into this like me.
    Thanks
  9. itrsleeper
    this is the d15b8
    this is the d15b
    they both look the same, but i dont know how they mount to the block b/c of the timing belt cover
  10. Angus
    Angus New Member
    Kansas City
    Thats what I ran into. I did not notice a difference untill bolting it up. The z6 bracket wasn't even close to parallel to the deck surface. The rubber would be way off.
  11. itrsleeper
    tonight ill crack open a beer and take off both covers for ya, then i will see if either one is diff. i gotta buddy who loves d-series and ill ask him.
  12. Angus
    Angus New Member
    Kansas City
    Very cool!! The dealer was not much help since I did not have a vin for the a6 block. Thanks
  13. Angus
    Angus New Member
    Kansas City
    OK, I'm not smart enough for pictures so discriptions will have to do. The mount bracket I need has the block mounting bolts that are inline verticaly with the block same as the cylinder bores. My z6 mount, which will not work, has the bolt holes at a slight angle. Apparently the z6 block uses a slightly bigger water pump so the bolt holes are tilt a few degrees. Keep in mind I am describing the holes that bolt to the block not the horizontal rubber mount surface. The result is a badly tilted z6 bracket on an a6 block. Clear as mud huh.
    Thanks for the help, your brackets just might work.
  14. itrsleeper
    sorry bro i cracked open one too many last night and woke up on the couch. i will try again, this time ill take off the covers then crack open a beer....:beer::drinks_drunk: :alcoholic:
  15. Angus
    Angus New Member
    Kansas City
  16. itrsleeper
    this is as far as i could get tonight, hope it helps
  17. Angus
    Angus New Member
    Kansas City
    I cant compare mounts, but the water pumps are the same. The z6 block is different in the water jacket area and I think thats why the motor mount bosses were drilled at an angle. I think you have what I need! What do you need for one, shipping to KC 66202? Thanks much!
  18. itrsleeper
    so you want the mount??
  19. Angus
    Angus New Member
    Kansas City
    Yes. I can do Paypal if you get me a total shipped to 66202.
    Thanks
  20. itrsleeper
    South Bay Honda - Honda Automotive Parts Store
    8 11910-PM3-700 BRACKET, ENGINE MOUNTING No Color 1 1989 CRX 34.38 24.75
    here dude, its not really worth it for me to spend all that time getting it off. you go through this place and they are pretty quick w/ shipping and at 25 buck it aint bad
