My son replaced the auto trans with a manual on his Honda Civic. When we turn the ignition off we can not remove the key. Since he is presently in Iraq my workaround is to disconnect the battery and this resets the cylinder. Is there a way to disconnect the cylinder to prevent this from occurring or should I check for a short. Not sure if he had this problem after the engine/trans swap.
Thanks for any info
Thanks for any info
