Need help! Distributor position!
Discussion in 'General Tech and Maintenance' started by bistec, Apr 29, 2007.
  1. bistec
    bistec Project EH23
    Hi guys, I need help. How do i position my ditributor to make sure that i'm putting it the right way and not messing with the firing order. Please help asap. Thanks!
  2. free crx
    free crx New Member
    Bay Area, CA
    assuming the car in question is a honda you can only put the distributor in one way. The distributor drive is offset to one side so you cant put it in 180 degrees out. It also helps if you start by making sure the engine is at top dead center (TDC).
    Cheers
    PS check out this site Free Downloads of Civic Wiring Diagrams and Schematics from HELMS Manuals - At Spoonhonda.com to get the helms manual for your car....downloadable and free....;)
  3. bistec
    bistec Project EH23
    Thanks a lot!
