t3t4delsol
Member
Ok well about 4 months ago my headunit shut off on me while driving, I checked all my connections and fuses everything looks good. I started checking my power feeds into the unit and there is no power coming into the memory wire, Also when the unit went out my clocked went out too. Now my car has failed emissions for 3 months in a row because of ecu readiness, because the ecu resetting itself everytime the car starts. I know that the radio, clock, and ecu use the same power feed, But my question is Ive checked all my fuses and they are good, Is there some kind of inline relay that controls a constant power supply to this stuff? Could I just run a straight power in from my battery and connect the clock and ecu up? I already ran a straight battery feed in for the headunits memory. Possible main relay going bad?
Any insight is appreciated
