Need Help my First swap
fr3nchy
I am putting in a JDM b16a(SIRII) into a 99 Honda Civic Dx(Coupe)
My car is OBD2b and the B16a(SIRII) is OBD1. In order for this to work I bought a Conversion Harness OBD2b - OBD1 from Boomslang.
We started the swap last night I already know that I need the plugs from the b16 harness for the Vtec Pressure Switch, Knock Censor, and Vtec Selonoid I have already ran these wires to the Harness.
Now I remove the plugs from the b16 harness for the injectors, altenator and distributor.
-We have the injector wired up and everything seems to have a good connection.
-The altenator plug from the b16 has 4 wires and my obd2 harness only has 3 wires I was wondering what wire I do not use?
http://freehost.h22a.ca/hosted/IMG_0943(Medium).JPG
-The distributor for the b16 has 2 clips
http://freehost.h22a.ca/hosted/IMG_0952(Medium).JPG
and my obd2 harness only has one
http://freehost.h22a.ca/hosted/IMG_0951(Medium).JPG
We match up all the wires except for the dark blue on the b16 distributor(on the clip that only has 2 wires.
After looking thru manuals I think that the blue wire is the tach.
My question is where do I plug this blue wire at?
Thanks for the help :D
[post=407557]Quoted post[/post]​
Do I hook it up to the conversion harness or theres a plug in the engine bay on the drivers side that has access to my tach?
either. theres a tach wire by the dash or the service connector at the shock tower on the drivers side and just run it into the ecu.
[post=407563]Quoted post[/post]​
Thats what I tought thank alot you would happen to know what wire I eliminate for the altenator would ya?
no idea.
quite frankly, i think the best thing to do would be to get an obd1 alternator from autozone. 94-05 del sol vtec has a b16a3 and is pretty much the same thing.
