need help on needed parts for h22a swap for 94 honda accord ex swap
my motor in my 94 honda accord ex coupe went bad on me so im decidin on the h22a obd1 engine swap so i need advice on the parts needed for swap?i wld really appreciate it
It's really a bolt-in affair. The stock mounts can be re-used, although you can upgrade to the Prelude mounts or after-market mounts if you want something a little beefier. Other then that, it's pretty much a straight bolt-in...
That's not really a big deal. An exhaust shop can easily fix it...
your also gonna need a 94 lude driver side mount. Throttle cable w foot pedal from lude (94). p06 chipped w h22 basemap. h22 distributor housing w internals from a 94 d16z6. lastley make sure your fuel injector resistor box is wired up rite cause w/o it it will never start. make. make sure to put new auto-tensioner as well when ur replacing timing belt,change water pump too.
