Originally posted by JDMilan@Jul 1 2004, 11:46 AM
I would suggest first and foremost opening up your motor and see what actually went, probably the issue is either a melted piston or a ring or two went.
Either way, I would get the bottom end resleeved so that you'll be able to run more displacement and thus gain more tq and a tad bit more hp figures over your current setup.
Bottomend I would go with "personally":
Resleeved to either 84mm-84.5mm, and there are tons of types of sleeves out there
Crower rods/Eagle rods/Cunningham
IB pistons/Weisco pistons (getting anywhere depending if it's a daily driver, and what type of octaine is available but I would run 12.0:1 CR)
New ARP rod bolts, new OEM seals, gaskets, etc...
Head: Well this could be endless but now is the time to upgrade since your motor will be apart.
Budget wise I like ITR cams, good midrange, cheap, and OEM
Skunk2 makes pretty good cams also, check out my cam reference section on top of either this page or the engine building page.
ITR/Skunk2 IM, and a TB in the 64mm-68mm range.]
Tranny: well since you have the ITR tranny already then if you don't have the optimal final drive then I would upgrade that also, a good clutch and flywheel setup would be bought right about now.
Engine Management:
I have always personally run the oe units, but if I was to build an good NA setup I would go with a hondata unit.
Good tires, on light, small diamater, wide rims would be good for both draggin and street use.
Suspension, well there is tons of shit out there but I always seem to hear good things in the simple stuff, such as a poly motor mount inserts, you can either buy them or make them youself.
good luck.
