Need help on what to get
Status
Not open for further replies.
SolPWR
OK i got a 89-91 b16 SiR engine which is OBD0 and I have a 94 Del sol Si which is OBD1, What do I need to make this engine work?
you'll also need to switch your injectors or the clips because obd0 and obd1 don't match..
are you gonna run an obd1 ecu or obd0?
This topic has been closed :locked:
Why? It is in the wrong place. Please post your topic in the right forums. Hybrid is not for suspension or interior posts. EG is not for EF questions, and so forth.
If you have any questions, please PM the moderator who closed this topic.
-The moderating Team
Status
