Viperlocc_B18C1
Alright, i have a B18C1 with CTR pistons and its gonna raise the compression close to 12. What head gasket should i use to lower it down just a bit? or can i run without the thicker gasket? i was looking around and spoon and mugen are out as they are very thin and RAISE compression. Im used to Supra head gaskets (1.2, 1.5, 2.0mm gaskets) and been looking and seeing 80mm, 82mm, 85mm gaskets from hks and greddy....WHAT SHOULD I USE
