Need Help: Std Cluster To Si Cluster Swap
SyLee Duk
Member
Hey,
Im lost on this....ok I have a 90 STD hatch with NO tach, and I got a 90 Wagon cluster at the junkyard today(which is the same as the Si cluster, about 99.9% sure) and I was pretty sure it is just a plug and play, but everythin works besides the tach. So does anyone have pics or info that can help me fix this problem?
Thanks :D
if i were you i would get a continuity/electrical tester and see what is up with your new cluster, because it should be plug and play... my 89 crx si cluster works perfectly in my 89civic DX... Maybe the wagon cluster is different, but i have not heard of that before...
yah the wago-vans :blink: have the same gauge cluster as all the other EFs with tachs.
